Thread: MMM guts?
lutach
lutach's Avatar
06.01.2008, 12:29 PM
The trouble with TECs is that they require between 3-5A by themselves to operate, which would reduce runtime...
Yes, but that AMP rating seems to be the MAX on most units depending on the voltage you use. You can get away with a Rx pack or a small lipo for around 15-20 minutes bash or race. The ones I have only drew around 1A max to provide plenty of cooling and it did not reach it's max cooling and that's not even with a decent heat sink on it. You can even get a TEC with a thermal management unit that will only activate the TEC when things reach a certain temperature. That's the route I'll be going. I was planning on using water cooling, but the TEC seems a better device for cooling.
