09.25.2005, 08:39 PM
I have some gp 3300 and 3700 not matched. I not sure on zapping but I don't think so. MIne does good. From what I have read zapping gives you more volt for a few cycles. Then it goes back to normal voltage. It also shorts the life of battery alittle bit.
As far as ratios. How many times does the input shaft turn to the out put shaft. LIke the pinion and spur. Example 66 tooth spur and a 22 tooth pinion would give you a 3 to 1 ratio. If you know the tooth count on the gears and such I could figure it out. I just don't have a clue what a savage runs.
That Is cheap squee. Pm me a site if you could.
