Thread: Revo Gearing
squeeforever
squeeforever's Avatar
09.25.2005, 10:19 PM
then i would go with a smaller clutch bell.... with a 14 tooth clutch bell and a 40 tooth spur you can get 20.33 to 1 gear ratio in second gear.... look at your manuel that came with your revo; on page 45 there is a chart with all the gear ratios with 14,15,16 tooth clutchbells; 36,38,40 tooths spurs; and standard, close, and wide ratio gears...
