09.25.2005, 10:30 PM
How is the slipper setting? if it is too loose, it will hurt acceleration. Otherwise, gearing down is the option(or replace the motor). Drop a tooth on the clutch bell, make sure the slipper is tight and possibly install a better pipe(LMK if I can get you anything, obviously). Small track there. Definately don't need top end.
