Edumakated
06.03.2008, 11:09 AM
Originally Posted by Joe Ford View Post
Same fans...no shipping 1kg of them to Australia ;) , and ANY running without the fan, separate BEC or not, will void your warranty.
Joe:
Castle may want to consider using a fan with a longer wire so it can be powered off the receiver instead of the ESC board. Fan failures seem to be pretty common and caused by either 1) blades hitting the grills of the case or 2) the fan connector breaking off the ESC board.
One mod folks have been doing is adding small spacer on top of the fan or grill to prevent the blades from hitting the grill. Additionally, others are dremmeling out the bottom of the case a hair to prevent the ESC board from hitting the bottom of the case which is what is appearing to cause the fan connector to break.
