06.03.2008, 11:06 PM
Steve, thanks for the kind words. I am a better wrench than a driver. The fan runs off of the rx. Regarding the brakes, I just feel more comfortable with the mechanical brakes, you can adjust brake bias, there is less wear and tear on the gears/motor/esc. When you use motor brake only you bascially lock the spur gear, but the diff will then decide how much brake to give to the front/rear depending on traction. Too iffy for me. Don't get me wrong, motor brakes work fine, it makes the buggy lighter and there are less things that can go wrong.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
