jhautz
jhautz's Avatar
06.04.2008, 12:38 AM
Originally Posted by Joe Ford View Post
Same fans...no shipping 1kg of them to Australia ;) , and ANY running without the fan, separate BEC or not, will void your warranty.
Sounds like you boys need to get some fans in stock!!! I'll take 6 please. That should last me a week or so, then I'll place another order. Oh yea... and a flip top esc case would be nice so I don't have to tear the whole dang thing down every 30 minutes or less of run time to replace a fan. I already have 2 tabs breaking off of one of my cases from opening and closing it so much for fan maintenance. While your at it add a couple new cases to the fan orders.
One of the white plugs has already completely broken off of the circuit board from hitting the bottom of the case so I cant even run a fan on it the way it was designed. I guess I'm out of luck on that one. Oh well... when it dies, it dies. Hopefully the Tekin controller is available by then.
Warranty void if running without a fan is the craziest thing Ive ever heard since I haven't heard of a stock installed fan lasting more than an hour.
Originally Posted by lxmuff View Post
I have a hard time understanding the warranty is VOID if NOT using a fan.
The POOR design of the fan in the esc makes it IMPOSSIBLE to run with a running fan.
Those things break within minutes of use.
Why did you not steal the design of the concept that works with modded MMs?
++++1!!!!
Heres a picture of the bulletproof 1/8 controller. Does this void the warrantee? Its the only way I can keep a fan on it.
Originally Posted by dirt101 View Post
where are you guys taking temps. at on the MMM. seems like it would be kinda hard with that large plastic case.
Your right. It is kinda hard to take a good temp with the cage on it. I get the highest readings shooting straight down the top fan hole to the heatsink. I'm sure the internal temperature is significantly hotter than the reading off of the top of the heatsink, but we will proobably never know for sure.
to make it...
or break it...
Silent...But Deadly
