killjoyken
RC-Monkey Poo Flinger
killjoyken's Avatar
06.04.2008, 01:25 AM
Yea, you must. Whoo Hoo!!!! We found one. Now just clone it and send one like it to all of us.
Just curious? What are you doing with the MMM? I think they might be OK if you are just running it around the street or in the park or something. But any kind of rough handeling and they are toast. Mine ran fine all thru set up and some testing at the local park, but the minute I put it on the track it was a gonner.
Rough handling? More like abuse. Last time I took out my Savage (with MMM) I snapped 1 heavy-duty dogbone, bent another and cracked the shock cap on one of my Aftershock shocks. If it wasn't for the shock cap I would've kept on jumping. 10-12ft jumps...and unlike a cat I don't always land on all fours!
The fan has stopped twice though. 1st time I switched the MMM off then on and the fan restarted. 2nd time a blade of grass blocked it. Removed grass and it worked fine. Also I run in very loose dirt/gravel.
No mods to the Monster. I was running an 8XL, now a 1515/1.5d, both on 4s. I'll probably be running a 1515/1y on 6s this weekend.
