Django
06.05.2008, 03:44 PM
Originally Posted by Cain View Post
I also pm'd truerc to see what they say about there packs if its a hard 30mm or if there is some give.
Beat ya to it!
Originally Posted by TrueRC
Yes sir its 30mm on the dot.
A fresh resupply of packs should be available around the 15th
Best Wishes,
Dan
TrueRC
Originally Posted by DJANG0
Subject: 2S2P 15C 8000mAH Dimensions
Hey Dan, I was just wondering if the measurements of your 2cell 15C 8k's pack on the web site is dead on accurate. I'm looking for some lipos for the soon to arrive ERevo and the battery tray dimensions are 165mm L x 51mm W x 30mm H. As you can see, the hieght of the tray and your battery are the same. I'm hoping that there would be enough wiggle room to make this combination fit.
Of course, I'm buying batteries before I have the truck in front of me, so there's some hesitation there, wanting to make sure this will all come together correctly.
Oh, I see this was back before we got confirmation on the actual battery box dimensions. No matter. 30mm high is 30mm high, either way.
Dan has said before that he's using Enerland packs. I am hoping the new batch of cells he mentions are each a faction thinner than the old batch. Maybe we'll get lucky and the difference will add up to a couple of millimeters.
/crosses fingers
