Matthew_Armeni
Matthew_Armeni's Avatar
06.06.2008, 03:02 AM
I run both my MM's at 6s, one with a 1515 3d Neu and the other with a 1300 Medusa (both 50mm and 60mm versions) and also a 1500 Mega Motor. I haven't had any problems, but I am right at the components maximum voltage level and I don't run any cutoff. All the components on the MM are 26v and the caps are 25v so it really isn't recommended, 5s shouldn't have any problems at all though because you leave yourself some headroom.
  Send a message via AIM to Matthew_Armeni
