Patrick
Patrick's Avatar
06.06.2008, 11:03 AM
Originally Posted by mkrusedc View Post
I could but stock a larger pinion won't fit with out dremeling the motor plate or motor fins.
No need to touch the motor to put a bigger pinion on, just the motor plate. I know I've said something about this to you in another thread quite a while ago and I surprised you still haven't spent a whole 5 minutes with a dremel or even a small file to get your top end speed back after putting the 1/8th diffs in.
Get it done!
