Happywing
06.07.2008, 02:39 PM
If it went up in flames -- it wasn't a BEC failure. Most likely it was over current -- setup incorrect, and possibly demagged the motor. Every major failure like this that we have seen have been setup problems where the current rises from a damaged motor so quickly that the over-temp doesn't have a chance to kick in.
Patrick
Mine burned. I put the Max back in and it is fine. Same motor, same connectors. The only difference is one is a MMM and one is a MM...and one works and one doesn't.
