Thread: Brushless RC8
TDC57
TDC57's Avatar
06.08.2008, 02:47 AM
This buggy is not so light because i use the 1515 motor, and a 5000mAh 4s pack, and the MGM controller is twice the weight of a MMM.
So it weight 8.3 lbs.
If i race alot this summer, i'll sell the 1515 and buy an 1512 1.5Y and change the 5000mAh 4s FlightPower for a 3200mAh, 5s.
What’s wrong with that weight?. What would you be with a 1512 1.5y and 5s 7.5 lbs?. Does it make that much of a difference?
So if I understand you correctly, you'll get longer runtimes out of 5s vs. a 4s?? What 10% longer with a smaller mAH??.. (IE) 5000mAH to a 3700mAH) will improve you weight and runtimes??.
Thanks for your time and again.. Great build..
Nothing!.. Hahahahaaa..
