06.08.2008, 03:53 PM
Originally Posted by speed demon View Post
I checked and didn't see anything in the cd but will check again. Can you tell from the pic what connector that is? If I know that and find an adapter pic that would really be a big help.
The tap on the battery looks alot like a hyperion tap. The wire order is the same on most taps, main pos and neg at each end, and the other wires should stay in the same order no matter what tap used.
