RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
06.10.2008, 08:31 AM
Originally Posted by dirt101 View Post
IDK why my CRT is so heavy. im pushing 9.6lbs with 3s. maybe yours will end up being more than 9lbs.
That is in the ballpark for weight(assuming you have a healthy 3s pack to handle the load). 9 pounds will likely be an inaccurate weight - the "human scale" method is nowhere near accurate enough for these light weights, so when dropy gets an accurate scale, his truck will tip the scales at well over 10 pounds. Most truggies can get around or just under 10 pounds with 4s, 5000mah and some thought. 10 pounds and change is about the norm with a 5s setup. Not sure I would even think about 3s on a truggy personally. :)
