Originally Posted by riceman
Shoe goo and fiberglass drywall tape works very well. Cut a few strips of the tape and glue them down from the inside in a cross hatch pattern. I'll sometimes use masking tape on the outside to keep the cracked pieces together while I goop it back together. This is very strong and will keep you running. I've even glued two whole halves of a shell back together in this fashion.
Second the shoe glue and reinforce with mesh on the inside. Haven't used the drywall fiberglass mesh due to having two rolls of the black roof patch material around. Works good to reinforece the body post holes with this stuff also.
