06.11.2008, 10:06 AM
Brian - one more question.
What controller are you using with the higher speed running Neu's?
If MM what Punch control setting? If other (ie: MGM) are you using any acceleration limiting?
In my lower 30-35k setups I don't tend to use more than 20-40% punch control, but in a higher ~50k setup I could see punch control set higher to prevent the motor from pulling higher current peak to wind up the motor.
“Everyone has a right to be stupid; some people just abuse the privilege.”
