Thread
Locking the revo in 2nd gear to use motor braking/reverse
99
Trick440
06.11.2008, 07:44 PM
BrianG, I just want to confirm the pin mod inside the tranny. I understand you are using 2 pins coming from each side. Now my question is...
Are you using the stock pins? And if you are not, what pins are you using?
Thanks
Trick440
Find all posts by Trick440
