GriffinRU
06.13.2008, 10:31 AM
Thanks rabosi! I added the continuous ratings for the Neu's based on the page you provided.
I also add Feigao power ratings, but that was kinda fudged. I took the data from Feigao's datasheet. I figured an arbitrary 35k rpm max speed and divided that by the kv (to get voltage), multiplied that by their "max amps" figure, and then rounded up to the nearest 100w. It's not perfect, but it should be fairly close. And the power figures work for all winds of a particular series (S, L, XL) so good enuff!
Bustitup: No, wouldn't want any warnings. But the mods here aren't post nazis, so I don't think I have to worry. Besides, if anyone got warnings, it would be lincpimp.
Haven't updated program in long-long time, but still can be helpful. Motocalc sample file, can be updated from motocalc website.
It is a good thing that you start adding power ratings to your calculator, but you cannot draw max amps at top efficiency (~35k).
