06.13.2008, 10:59 PM
Well got the ESC all wired up and got the deans plugs on the batteries and charger. The battery was taller than I thought, might actually try to cut inside the battery tray down lower so the battery can sit lower as it does make the left side of the body sit up abit. Also used a dremel and made the flat spot longer on the Neu Motor. All that is really left now is to mount it all in and charge the battery and hopefully it will go.
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
