06.13.2008, 11:12 PM
Originally Posted by azjc View Post
also I HIGHLY suggest you run the ESC at low power start up you dont want the high power start, it advances the timing and your motor will run much hotter and you dont need that much
Start up may need to be set to high to get the neu to start well. High timing setting will cause motor heat. Also, some punch control will help with runtime. I have to run high start power with my plett with a MM, have not tried it yet with a MMM.
