06.13.2008, 11:18 PM
Nice looking truck, amazing that a cretinous noob like yourself got that together!
Seriously, that truck does look good. Should have plenty of power with the neu 5k lipos. Not sure about the yellow on the split loom, but your wiring is very tidy! .
Just a tip on the fan you are running. If you can get it turned at a slight angle, you may be able to bolt it on thru diagonal holes, instead of the bolt being next to each other, and the other side unsupported. The fans like to be help tight ad not flex, I have had issues with that. Otherwise your build looks great. I look forward to hearing about how much fun you have with it!
