Buzzsaw46
06.14.2008, 12:55 AM
Originally Posted by TexasSP View Post
I ran my setup again today after getting a thermometer. Temps were 125-135 esc, 100-105 batteries and 165-175 motor. Ambient temps are 95-98. The thing is I am geared 20/68 now, but yesterday when I was 22/68 the esc shut down. So I don't think gearing the pinion higher is the answer and I don't have anything smaller in pinions right now. The testing was done mostly in thin grass (only slightly thicker than say a golf course). I got to run for about 5-8 minutes until an unforeseen object caught the maxx and busted the rear shock tower. It was still drivable though dragging its butt on the ground.
Do you have air holes in your body? Those temps aren't terrible for the kind of heat your running in, a little air flow might be enough if you dont have some already.
