traxxasrevony
06.15.2008, 07:18 PM
how many amps should i enter on the speed estimator this is what i got with 70 amps on 22/40
Differential Ratio: 2.8461538461538462
Transmission Ratio: 2.5
Other Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 22
Total Voltage: 14.8
Motor KV: 1130
Tire Diameter (inches): 5.9
Tire Ballooning (inches): .5
Motor Current Draw: 70
Motor coil Ω: 0
Spur/Pinion Ratio: 1.82 : 1
Total Ratio: 12.93706 : 1
Tire Circumference (inches): 21.68 inches (550.6 mm)
Total Motor Speed: 16724 RPM
Vehicle Speed: 26.54 mph (42.63 km/h)
Estimated Adjusted Speed: 26 mph (41 km/h) - 3% loss
Effective KV Value: 1130
KT constant: 1.2 oz-in/A
Motor Torque: 0.44 ft-lbs
Final Torque: 5.64 ft-lbs
Final Power: 1036 watts (1.4 HP)
