highflier
Emaxx- FLM wannabe
06.15.2008, 10:01 PM
Just want to make sure. The rubber o-rings go inside the diff case not on the ourtside. I did not shime the spider gears (I think that is what they are called) however it looks like I could use a shim on the pinion to fully seat it on the ring gear.
Does this sound common?
Where is the best place to get shims?
Highflier
