VintageMA
VintageMA's Avatar
06.15.2008, 11:19 PM
Originally Posted by Sammus View Post
Can't wait for someone to come out with a new chassis that takes bigger batteries.
I'm even considering buying the chassis for my revo. A123 are 65mm long, 26mm wide, so you could fit 4s (shotgun config) or 5s (same as 4 with the 5th going sideways at the end..if you get me :P) A123 packs in there without the doors, just some elastic or velcro straps to hold them in.
I'm sure it can be done - if you run the pack side-by-side instead of shotgun you could probably do 6S on each side (26*6=155mm long) with a custom velcro to hold it in. You'd be looking at about 1lb of batteries per side.
“Everyone has a right to be stupid; some people just abuse the privilege.”
