MGM low voltage cutoff-=test is done=-
david lamontagn
MGM low voltage cutoff-=test is done=- - 06.16.2008, 12:20 AM
OK, tonight, i've charg my flightpower 5000mAh, 4s pack and put it in my mugen truggy to make a little street bashing session.
My MGM 16018 was set to "reduce RPM" mode.
So i began to drive my truggy realy hard on the pavement, and after about 8-9 minutes, the truck start to be realy slower on top speed and acceleration was smoother, with less punch. So i decide to came back home and reprogram the MGM on "race mode".
Return on the street and continue my street baching and now my truggy was very snapier, i can flit it on it's lead and the acceleration and top speed was incredible. I've continue to drive it thrue i start to feel a slighly drop in power.
You know what???? I've drive another 10 minutes before to feel the power drop
I've plug the pack on my Hyperion and the cell was at 3.5 volts, and when the pack was at 16.8 volts, the capacity was at 4500mAh, so i stop the charger, and i'am sure that if i would have let the pack on the charger thrue the end of the entire cycle, the pack would take another 600-700mAh.
So in conclusion, the LVC on the MGM controller is a realy sh.....t
Now i'll continue to drive my truggy on "race mode" and stop to drive after about 15 minutes of runtime.
I'am sure that my little MM did the job better than my MGM
When the next batch of MMM came back in stock, i'll order one for sur
