asheck
06.16.2008, 05:27 PM
Sounds like your switch is sticking.When you push the button can you feel if it's working?When that happened to mine I split the case and took out the oring that seals the button ,I didn't need it to be waterproof.With the hv I would say any where around there will be fine.It will mostly be up to your batterys.The motor should not get hot.
