azjc
06.17.2008, 12:58 AM
Originally Posted by speed demon View Post
Artur said I should be ok as long as I try to stay under 50amps constant and so many volts...sorry forgot the number but if I set my charger to 4.1 per cell that should give me enough margin. I doubt i'm the only one trying 6S on an MM but if I see white smoke I'll know why.
with the Medusa 1600 motor I would expect you to exceed 50 amps closer to 70-80 on 6s
