lutach
lutach's Avatar
06.17.2008, 01:04 PM
Originally Posted by Cain View Post
Who is a good online seller for the Eagle Tree products? Also, I will be using this with a Mamba Monster ESC and a motor that draws a max of 105Amps (the neu is less that I have).
Exactly how do this work by the way?
The device measure between your battery and your ESC. It will show you how many AMPs your controller/motor combo are pulling from the battery. Your Neu might be rated for 105A, but you can be surprised by how off that can be. Spikes when starting a car can be up there in the 150-180A range. Eagle Tree also has a sensor for RPMs. You can check out Eagle Tree's website to find dealers or buy from them directly.
