Originally Posted by Pdelcast
Why the 1212-8 package? The footprint to silicon ratio is better on the larger Powerpak FETs...
I am playing with a version of the Monster that is stackable, and can use 30, 40 or 60V FETs. I already said that earlier...
I just had an idea that the more FETs would be better? The 1212-8 is roughly half the size of the larger PowerPak and I keep thinking the more the better as each FET will work less to produce the same power as less FETs. I know I'm not an engineer and what we think off might be possible in our heads, but not in true life application. But since you are working on the stackable Monster, when will the HV one be available? Will you be having other guys put the controller to the test or will it just be team drivers?
