Sammus
Sammus's Avatar
06.18.2008, 08:02 AM
A123 are probably the best case as far as lithium chemistries go, and just happen to have max charge voltage at 7s lining up exactly with that 6s lipo, but with a higher nominal. the huge voltage drops these cells experience probably makes up more than the difference though.
When I read Li-Ion I thought you were referring to the 3.6v nominal cells...A123 are 3.3v nominal, so what li-ion's were you looking at that are 3.2v nominal?
