GriffinRU
06.20.2008, 09:07 AM
Originally Posted by krunk View Post
Artur, Great job with evader's ESC.
Hopefully you can help me too. I have a 15020 that is cogging horribly. I have tried everything in thread with no help. It also does something wierd. If I remove the BEC (black jumper) the ESC does not work at all. Have you ever had that problem?
PM sent.
I will check for 5-6V at red wire on ESC's interface cable. If you do not have correct voltage here then ESC would be in Off state.
To all:
Thank you for comments,
