lutach
lutach's Avatar
06.22.2008, 10:44 AM
Try a 13T pinion. The Neu 1515/1Y has a Kv of 2200 and the 9XL is at 1660 or so. You could also try different timing on the MMM. A 2 pole Feigao likes the low timing or 0 degrees in other controllers. Go with normal and see if that helps.
