Motor Shaft: Grind Yes or No? -
06.22.2008, 12:02 PM
I'd like opinions on whether it's better to grind a flat (or divit) for the setscrew, or leave it round?
Also do most of you use Loctite on the pinion setscrew? If so, then do you use blue or red?
Blue is temporary, red is semi-permanent and green is permanent, so I assume green is a no-no.
Appreciate your input.
