Originally Posted by cornolio
thanks for the tips.ill try that today
One rule that I try to use depending on motor of course is if I go with a higher Kv, I will always go with a smaller pinion to match the speed and keeping AMP draws about the same. If you are really into speeds over 50mph then it's a different story.
