TDC57
TDC57's Avatar
06.22.2008, 08:24 PM
Originally Posted by DRIFT_BUGGY View Post
My Neu 2.5D come with a little flat spot in the middle of the shaft. I ended up using a dremel and made the rest of the shaft flat (didn't take long at all). I then mounted the motor and realised that the spot that come with a flat spot is where the set screw went anyway
I love you!! Not in that way mind you!, but you just saved me from doing exactly what you did.. I just got a new 1512 2d with the same flat spot and tonight I was going to get out the dermal and continue the mods.. Now I wont!..
Thank you "DB"..
Nothing!.. Hahahahaaa..
