tc3_racer_001
tc3_racer_001's Avatar
06.23.2008, 04:47 AM
I may be wrong, but it seems to me that your MGM controller came with double wires for running dual batteries and dual motors if you wish to use that configuration. If not then you can just cap the second set of wires leaving them dead ended. That is the only reason I would imagine having dual wires.
if you watch the castle video i posted a link to in the appropriate forum jerry, you will see/hear the reason for dual wiring. its so such a thick wire doesnt have to be used... 2 thinner wires are more flexiable too. also, unless its a very special esc, then it cannot control 2 motors. only dc motors (brushed) can work as ac motors need the motors to be "read" and adjusted that way, rather than amps/voltage. hope this makes a bit of sense.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
