MetalMan
MetalMan's Avatar
09.29.2005, 06:43 PM
You'll just end up spending more to get a higher C rate pack, as well as pulling extra weight around (the 20C cells weigh a lot more than 12C ones!). Basically, you could shoot for a battery that is rated at 50amps continuous, and unless you do only grass bashing, it should stay rather cool. Even with heavy grass bashing, it wouldn't get so hot that it could damage the battery (with optimal gearing, though). The Maxamps batteries aren't bad, and if for some reason your Maxamps pack gets damaged, they will help you out with it/replace it (assuming it isn't user error).
