06.23.2008, 02:23 PM
Finnster is getting one - They are actually a little harder...
There is no big seal just a small o-ring which was a little bit of a pain to get it to stay on... not a biggie though
The spider is a different animal - unlike a normal diff the body is in multiple parts with long screws holding everything together. You have to put some grease over the screw holes to stop the diff oil leaking out when you are building it... With the spider it is a little fiddly with 6 gears but with a little time it seemed to go togther ok.
I built the front end last night and it mesh seems a little tight in diff case but hope it will wear in.
