06.23.2008, 05:25 PM
I don't know either. Sounds like things should work fine. I have spektrum in all my stuff and have no issues whatsoever.
BTW:
- Ch1 is steering.
- Ch2 is throttle.
- Ch3 is auxillary.
And the black wire on the throttle/steering cable faces the outside of the case, the red wire in the middle, and the white/yellow wire faces the inside of the case. If you have the throttle cable reversed, it won't work (but won't damage anything). Try flipping the cable.
