06.24.2008, 03:47 PM
If I remember correctly the lower rack stays in, and two flux capacitors are used.
That makes sense, if you just used one it would has 4th order harmonic vibrations in the anti-matter chamber. And leaving the rack in must help with servicing the inertial dampers.
