06.24.2008, 04:02 PM
I had an issue where my Hyper8 would cut out and it turned out to be a crappy BEC unit. It was simply overheating.
However, if the cutting out is caused by physical movement, you surely have a loose wire, cracked PCB, or something similar causing an intermittent break in contacts.
