magudaman
06.25.2008, 03:22 AM
The motor might be getting hotter because the MMM is capable of higher current and will have lower resistance while doing it. This means you run you motor hard during your runs now than you used to because the MM is not restricting that current flow.
Did you also up your batteries to 6s too?
