Originally Posted by david lamontagn
Check your timming setting on your ESC.
On a "d" wound motor, your timming should not be higher than 10 degre. 0-5 is the best. Higher and it'll heat up.
On a "y" wound motor, you could go over 10 degre
David
David
do you know the theory behind that is? this is the first time I have heard it and I am curious.......
