Originally Posted by azjc
have you tried playing with the linkage?
Well before the RPM hubs, the steering was perfectly fine. So I didn't think I needed to mess with the linkages...
Originally Posted by blueb8llz
if your not using stock radio, check your steering servo throw.
not sure if the revo is the same as my emaxx, but if your dust plugs ( the bottom is blue, and its plastic, you need the plastic wrench that came with the truck, it goes over the pillow balls) is too tight, then it will limit your steering. loosen that and is should be all good. plus, if those things are too tight in the rear, your shocks may not spring back up fully.
I loosened them, and it still seems to have the same problem. I will try to loosen them even more, but they are quite loose, so I don't know if getting them any looser will fix the problem. I will email RPM to see what they have to say...
