rootar
rootar's Avatar
06.27.2008, 07:09 AM
it tried changing everything on the radio at frist like you said but it didnt work but for some reason when i put the 1.16 firmware in there it worked, it wouldnt work on 1.07, 1.09, or 1.17 but it does on 1.16 i dunno why and if it keeps working good i really dont care why lol
first test i ran it for about 10 mins 84* outside i was doin acceleration runs seeing if i had the right center diff fluid in, heavy braking to see how fast the controller would heat up, and lots of turns see how well the low speed throttle control was...........
so far im impressed after that little run motor was at 135, mm at 120, battery stone cold, cc bec was around 115. this was no race condition testing but with smooth driving onthe track i should beable to run 15 min mains with no heat issues and with no fans, ive ordered one fan just incase i need it for the mm, and i know this thing has to lose some weight its only 7.4 pounds with no tires and wheels, throw the beadlocks with molded foams tapes and everything and it puts the truck over 10.2 pounds so thatll be another way to shed some heat if i need to is ditch these tires and wheels.
