06.27.2008, 10:25 AM
The MM Pro doesn't yet exist and when it will it won't support the Amps for a truggy.
5S could be pushing it on a MM to but many people have had success...
I think you might be better off with the ESC at that back closer to the motor and battery. I came out with a clean setup which I can show later.
What is your issue with the front brace? Did you realise the order of assembly is a little off. You need to postion the front brace BEFORE putting in either the centre diff assembly or the front top plate...
