kostaktinos_mt
06.27.2008, 06:39 PM
Originally Posted by TexasSP View Post
That is for airplanes, not trucks. Best to stick with 0 degree timing as to not heat up too much.
not true... start-up stuttering and bad efficiency [including heat-up] can be seen [conditionally] when running 0 timing on 4+ pole motors... 10 degrees is the absolute minimum that i would run a 4poler, with 15 being a better suited timing setting for low-kv 4polers...
just my 0.02...
  Send a message via MSN to kostaktinos_mt
