jayjay283
jayjay283's Avatar
06.27.2008, 07:21 PM
The brakes are really bad on the 8T-15-1y/MM no matter what the setting I have it at, loud noise that just cant be good for the motor or diffs. I need mechanical brakes ! I know the pros and cons, can always put is back minus a couple holes im going to have to drill. Heres my idea
old pic but setups the same:
1. use 4 U.E TMaxx Servo mounts 'link' and bite the Tekno brake/steering servo setup
2. Put receiver in the waterproof RX box from my emaxx in the rear behind the battery
4. flip over the esc mount so it faces angled towords the front for a bit more air
5. ordered a brake spacer for the motor from Mike.
should make the wiring alot cleaner keeping most of it in the rear, what do ya think ?
